Mowing Greasing Frequency MMM
   / Greasing Frequency MMM #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
I've been mowing with Kubota CUT's with 5 ft MMM for 16 years now. I usually clean up (not grease) the MMM and the tractor after every usage. I'm getting older now and want to cut back on greasing if possible. Right now I grease about every 10 hours of mowing...that is about 3 mowings of the place. What frequency do you all shoot for.??
Cheers,
Mike
   / Greasing Frequency MMM #3
Once every blue moon should do.
My last company did biannual greasing on very hot motors running 24/7, and assemblies, and had longevity in the tens of years.
That’s a new greasing every 4,380 hours…
   / Greasing Frequency MMM #4
I grease my wheels every other use (2 acre lawn) and the spindles every five or six times. U joints are 10-ish ours and so is everything else.
   / Greasing Frequency MMM #5
it really depends on the bearing or bush I were always told by the bearing experts more high speed bearings were damaged by over greasing than under greasing but pins and bush's in mud or dusty conditions need regular greasing to maintain that dried up glob of grease that acts as the dust seal
   / Greasing Frequency MMM #6
I shoot for every 40-50 hours on my zero turns (but never over 50). I have about 2000 hours each on the zero turns with no failures.
   / Greasing Frequency MMM #7
I like every 25. Deck bearings are expensive failures.
Thanks TBN'ers,,,,,,, looks like i'll be be safe to extend the MMM greasing to at least 20 hrs........belt spindels... and U-joints. The front Gage wheels are easy to get at.........but that duo rear center gauge wheel set is very difficult to get at....as well as the U-joints.
Mike
   / Greasing Frequency MMM #10
Mike
The rear U-joints on the Kubota ZD mowers are awful to access.
12in Backhoe Bucket (A52128)
12in Backhoe...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
Universal Adapter Plate Skid Steer Attachment (A49462)
Universal Adapter...
John Deere GP Tractor (A50514)
John Deere GP...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
