Greasing Center Spindle On MMM????
   / Greasing Center Spindle On MMM???? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
I can't see a way to get to it while mounted. Might be possible with a 90 degree fitting so I have one ordered.
But I got to wondering about if it might be possible to drill a hole in the tractor floorboard directly above it and use a longer fixed tube. I haven't explored it yet to see what might be in the way. Thoughts?
   / Greasing Center Spindle On MMM???? #2
No doubt about it. The center spindle on my JD 750 mmm is a PITA. I have a manual grease gun with a 12 inch flexible hose. Still is not any fun but it is doable. Would be much easier if I had a helper. I could hold the fitting - tight on the zerk. Helper could pump the gun.
   / Greasing Center Spindle On MMM???? #3
OK - so I just got back inside from greasing the three spindles on my JD 570 mmm. The outside two - quite easy. The zerks are pointed outward.
The "thingey" I thought was a grease zerk on the center spindle - IS NOT. It's some form of chrome plated high rise fixture lock nut. All of a sudden I realized there were three of these chrome things on the center spindle. No way there would be three grease zerks.
Back in the house. Look at the owners manual. There it shows the zerk for the center spindle. Facing forward.
I had to take the flexible hose off the manual gun and put it on the DeWalt electric grease gun. Finally - I was able to get the Fit-N-Clip to hold on to the zerk.
You had better believe - if the zerks on my Kubota were this difficult to service. I'd be looking for some way to change them all over.
Three damn zerks and I'm filthy as a pig. DAMN - I even got black grease on the top of my head.
   / Greasing Center Spindle On MMM???? #4
A two handed (one on the hose, one to pump) gun sure works better than a three handed gun. It is the whole reason I bought my 2-handed gun. For greasing everything else I can use a old school gun.
   / Greasing Center Spindle On MMM???? #5
Do the center spindle with a ridged bent tube grease gun on Woods RD7200. All spindle bearing zerks straight up. After 26 years the lower bearing on the center spindle failed this year. Bearings are taper rolling type. Rebuilt with new bearings and seals. Careful, too much or too often grease will push out seals.
2009 Peterbilt 367 Tri-Axle Sleeper Cab Truck Tractor (A46683)
2009 Peterbilt 367...
International 3082 Series A Backhoe Attachment (A49251)
International 3082...
2013 Dodge Charger Sedan (A46684)
2013 Dodge Charger...
2017 Ford Fusion Sedan (A46684)
2017 Ford Fusion...
Allis Chalmers 6080 4WD Tractor (A49251)
Allis Chalmers...
2014 Dodge Journey SXT AWD SUV (A48082)
2014 Dodge Journey...
