Oil & Fuel Grease
   / Grease #1
Arkie Jim
Arkansas---71837
Mitsubishi/Satoh Buck--S470
Some tractor owners may frown at this post, but think about it for a while and it will make sense.
Pressure wash your tractor after each use and use a spray type oil or lubricant on the joints and moving parts.
WHY---Sand---Grit--Mud and other abrasive materials can cause wear within the moving parts.---Example---Steering---PTO--Chains--You get the idea--if dust can get in it--so can sand, grit and mud--works like sand paper.:)
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
Heavy-Duty Round Bale Trailer - Tandem Axle, High-Capacity Hay Hauler (A51039)
Heavy-Duty Round...
2017 Ram 4500 Bucket Truck (A51039)
2017 Ram 4500...
WARREN POWER SYSTEMS  100KW GENERATOR (A50854)
WARREN POWER...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
