grease zerks
   / grease zerks #1
rrboomer
ky
Hello all . I mostly lurk on this board and enjoy those who post. I have a 2006 jm284le type tractor with 45 hrs. and it was a crate. The zerks (grease gun fittings) on a few parts were broken by rough shipment. I just swapped out the good to use and left the bad on 3pth etc. Well today I replaced them and they were metric , 10-1 ! I have seen other postings saying they were sae or something and in my case that is not true.I just wanted to put my 2 cents in. Now if I could figure out the oil filter thing ? joe
   / grease zerks #2
What is the problem with the oil filter?
   / grease zerks
hello again ! no real problem ! There seems to be no answer to what filter crosses with the newer tractor. thanks joe
   / grease zerks #4
Yep, they're metric alright. My local ACE hardware had replacements. I read in an earlier post that a NAPA 1626 or a WIX 51381 oil filter is supposed to fit. They do on my 20 hp.
   / grease zerks #5
re: metric grease zerks
Harbor Freight sell two different sets of metric grease fittings. Each set is only $4.99. Part numbers are 93906 and 45732. Probably worth keeping a set around just in case.
   / grease zerks #6
I use a Napa Gold 1516 oil filter on my 2005 284. You might have to unscrew the threaded tube in the filter holder a little(and reposition the locking nut a little higher up on the threads) to insure full thread engagement in the concave top of a domestic filter. For that matter, you could unscrew the threaded pipe from the filter holder and take it with you to the autoparts store to make sure it screws into the filter OK before you even buy it. The only thing holding it in place on the holder is it's lock nut.
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2016 Isuzu NPR Beverage Box Truck (A51692)
2016 Isuzu NPR...
Land Pride RCF2072 (A50123)
Land Pride RCF2072...
Serco 200F Log Loader (A52384)
Serco 200F Log...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A53117)
2015 Top Hat T/A...
