Oil & Fuel Grease Zerks
   / Grease Zerks #1
sandyc
Veteran Member
Steep Falls, Maine
BX 2380
Strange....I have replaced a few of the zerks on my front blower (2781A) and the sub-frame carrier bearings. It started when I couldn't get grease into the fittings. Upon removal of these 8mm zerks I found half to have no springs or balls and the other half to have the balls sitting below the top of the fittings. Replaced the zerks and they take grease like they should. Maybe it's just me ....I don't think it is my grease guns (have two) running too much or not enough pressure. Even used my hand gun with the same results.
Don't know if Kubota got a batch of bad zerks but if you have trouble greasing your equipment you might want to try replacing the zerks. Would be a shame to spin a bearing because the fittings were sub-standard. Just saying!
Another foot of snow predicted for today....bring it on!
   / Grease Zerks #2
Kubota probably doesn't know that the bearing manufacturer sent them the bad goods! We try to write our warrantee as soon as possible although there is a time delay and often enough the time to write one for grease fittings is a lost cause.
Pair of Tractor Tires on Rims (A47164)
Pair of Tractor...
UNUSED KJ 7' X 20' METAL FARM DRIVEWAY GATE (A50460)
UNUSED KJ 7' X 20'...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
Kobelco SK200SR LC Excavator (A50860)
Kobelco SK200SR LC...
2022 Heli CPYD32C -KU1H Forklift (A48837)
2022 Heli CPYD32C...
1996 UTILITY 101" X 52' T/A FLATBED TRAILER (A50459)
1996 UTILITY 101"...
