grease zerk
/ grease zerk #1
blackpowder
One of the grease zerks on my l39 backhoe won't take grease.What's the problem ? It is located on the main boom.
/ grease zerk #2
Dirt or grime has found its way inside the fitting. If you can remove the fitting and soak it in a degreaser, or use a small pick and try and push open the zerk ball several times.
Good luck
sullyfe
/ grease zerk #3
I have gathered a stash of 6, 8, and 10 mm zerks, I find for about $.80 it is easy and cheap to just replace them
/ grease zerk #5
Sometimes the outlet hole where the grease goes through the zerk and into the bushing gets an obstruction against it. Sometimes it's pressure from the bushing or it's old dried grease. Worst case scenario is that it has rusted shut. My Ih dump has several on the leaf springs that no longer take grease and I don't like it.
/ grease zerk #6
When I first got my tractor, one of the grease fittings on the loader wouldn't take grease. There is a grease groove on the pivot pin, and it was turned 180 from the zerk. Tapping the pivot out enough to rotate it to allow the groove to face the zerk took care of my problem.
/ grease zerk #7
On most booms you have to put pressure on the boom for you to get grease
into the fitting.
JOHN DEERE 4760 TRACTOR (A64280)
JOHN DEERE 4760...
TRAILER MOUNTED 1000 GALLON NURSER TANK (A64280)
TRAILER MOUNTED...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
UNUSED KIVEL 48" PALLET FORKS (A64280)
UNUSED KIVEL 48"...
