Grease zerk problem
   / Grease zerk problem #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
I was getting my snow blower ready to be mounted on my tractor. So I get the grease gun to grease the auger shaft and had an "Oh crap" moment. The zerk was stuck in the grease nozzle not screwed into the auger after I greased it. Tried to screw it back in...no go...stripped! Rats! So I kicked around the different options I had (I was not going to tear this apart for a grease zerk) and finally decided to degrease the zerk and threads in auger shaft and use JB Weld on it. I've heard about that stuff but have never used it before. Do you guys think this fix will hold up or will the zerk pull out the next time I go to grease it? If I ever have to tear it down for bearing or such, I'll drill & tap for a new zerk then.
The blower is a 50" two stage for the BX 2230 Kubota.
   / Grease zerk problem #2
Personal opinion: JB Weld or any such product will be a waste of time in this case. You didn't mention the size, style or thread size of the problem fitting, so it's hard to advise on a practical solution, even more so without knowing what the access to the damaged hole might be. The thickness of stock the threads are cut into also comes into play. If you can get by with a straight fitting and can get to it, you might try a drive in zirk. I've used them frequently with good success. They come in various sizes, I use 1/4 " mostly, but larger ones are available. If the original is 1/4-28, the drive in will probably fit right in without drilling. They are made to fit in a 1/4" hole. and have barbs to fit snug and not pull out.
Thanks for the info, I never gave a drive in one any consideration. Forgot all about them. I'll have to check the thread diameter to get an idea what I may need. If the one I installed today comes out, I'll have one ready to try your suggestion.
   / Grease zerk problem #4
Local hardware stores such as "Ace" are usually great for stuff like this. I keep some on hand because I've had a similar problem.
   / Grease zerk problem #5
I had t replace 6 zerks on my splitter. I found some NPT threaded
zerks of the right flavor and just tapped them bigger to fit...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2022 Continental 16ft T/A Enclosed Trailer (A49461)
2022 Continental...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2013 MACK CHU613 (A50854)
2013 MACK CHU613...
