Grease Zerk Grumble
   / Grease Zerk Grumble #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Under my tilting seat is a zerk for the upper connection between the front and back.
When I try to access it with my hand pump grease gun it is no joy. There is no room for the hose and the connector.
So I went to a 90 degree zerk. Problem is that it is getting the heck knocked out of it as it is high enough to be hit by the under seat bar when I am turning on a slope.
Are there low profile zerks (maybe I should look at a 45) or is there a low profile pump head or a 90 head. How does everyone else with the 1800 series deal with this?
   / Grease Zerk Grumble #2
Maybe it's easier to put a plug in the zerk hole and just screw in the zerk when you want to grease it.
   / Grease Zerk Grumble #3
That is an excellent suggestion.
   / Grease Zerk Grumble #4
I see you have one a them fancy automatic tilting seats :) It never occurred to me the tradeoff might be you get no forward/upward tilt with that option. I thought all of PT's seats tilted forward.
There are lots of angled grease gun adapters for difficult to reach fittings but (here come a trade-off again) the angled ones can often be hard to hold in place to get a good squirt. An auto parts store should have something that would work.
How do you get access to add hydraulic fluid?
PT-1845 Upgrades and Improvements
Sedgewood
   / Grease Zerk Grumble #5
How about a remote zerk set-up. Google it. I have seen them a hundred times and know they are out there on loads of equipment. Right now I just finished up a ba****d of a cylinder and don't feel like making the effort to look it up. Basically, I got my butt kicked today.
   / Grease Zerk Grumble #6
I have an adjustable angle nozzle that I use there but I can not get the fitting to accept grease. If i remove the fitting, the grease flows through the fitting fine so the zerk itself is not the problem. I will have to try a small pick, then heat, then ?
Ken
Don't use heat. Take a look at the diagram in the manual. There are plastic bushings in one of the connectors...
   / Grease Zerk Grumble #8
Ken
Ken.
When I first tried to put grease in my 1444, it would not go. I removed the zerk and cleaned it out . Still could not apply grease. So I thought that if the pin was tight on the zerk opening, it probably would not take grease, so all I did was to turn the steering wheel as I applied grease, I guess it loosened the pin a bit, and it worked. They should have cut a grove in the pin or housings, like on some bearings I have seen.
   / Grease Zerk Grumble #9
Carl - thanks for thanks for the heads up!
JJ - Yeah, I have already tried putting the PT in various positions with no luck.
Ken
Ken
Ken, I just stumbled onto a possible solution. I broke my zerk off (we are talking about the upper zerk on the arm that hold the two halves of the tractor together). What I did was I put a floor jack under the center section and lifted it up. Just to get some weight off the upper joint. It took a bit of finessing. I then just undid the little bolt under the seat and pulled slowly up. I did not want to bump anything as if this thing moved I think I would push out all the bearings and washers and stuff.
I quickly extrated the broken zerk and put it right back in. No fuss, no muss.
Hope this helps.
Ruger Shop Crane, 2,000lb Capacity (A52384)
Ruger Shop Crane...
SKYJACK SJIII 3219 ELECTRIC SCISSOR LIFT (A51246)
SKYJACK SJIII 3219...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
INDUSTRIAL UNISAW TABLE SAW (A51248)
INDUSTRIAL UNISAW...
