Grease Points
   / Grease Points #1
Buffalo Trace
Nashville, TN
Kubota
Hello All - I have a BX2370 with MMM & FEL and have found 7 grease points on the FEL. Where are other grease points on the tractor or is that it. Thanks in advance for your response.
   / Grease Points #2
get yourself a service manual.
   / Grease Points #3
My Kubota L4400 Operator's Manual has all the Zerk locations indicated for the Tractor, and the other Manual - Front End Loader - has all the Zerk locations indicated fot the Loader. Hopefully you can obtain some manuals fot Your make and model. Best wishes.
   / Grease Points #4
Buffalo,
Sounds like you got it covered. I have a zerk for the hydrostatic pedal on my BX25. It is accessed through a little cut out on the floor mat by the pedal. They recommend that this one get greased after every 50 hours.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
Saxon Tri Wing Finish Mower (A52384)
Saxon Tri Wing...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A53426)
2020 VOLVO...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
