Grease Points on a TC18
   / Grease Points on a TC18 #1
BGM72
Rochester, NY
New Holland TC18
I recently did my 50 hour service on my TC18. The manual does not have good detail on where all of the grease points are located. The one that I could not even find a fitting near where they pointed was the three point. Any one have a better diagram to find all the fittings? I do not want to mis any.
- BGM72
   / Grease Points on a TC18 #2
Are you going by the manual that came with the tractor. I think there is a better manual out there that you can buy from your dealer. I believe it to be a service and parts manual. It goes into much more detail. I have not seen it but have heard of it on tractorbynet.
Murph
   / Grease Points on a TC18 #3
BGM72
They are refering to the balls in the lower links.
Solo
   / Grease Points on a TC18 #4
<font color="blue"> They are refering to the balls in the lower links.
Solo </font>
Yup, no fitting, use spray lube, or wipe something on with your finger.
2010 GMC Acadia SL SUV (A50324)
2010 GMC Acadia SL...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A52141)
2018 PETERBILT 579...
2001 Sterling L7500 Series VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A50323)
2001 Sterling...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
