Does anyone else suffer from having residual grease left behind the plunger when your gun runs out? Seems like everytime I change tubes and I retract the spring loaded rod, grease escapes past the plunger and oozes and oozes out of the hole the rod slides through. I end up "wasting" a lot of grease - I save it and use it for other applications outside the gun but it is still frustrating to not get the whole tubes worth through my gun. I use a Lincoln pistol grip gun and and older Sears gun. I use Chevron Ultra Duty No.2 grease (red stuff). It's real good grease (very stringy) but don't remember this happening with the cheaper Tractor supply grease (black) that I used to use. I wonder if the grease is not viscous enough.
Just wonder if this is an anomaly or do others experience this?
