Grease gun chucks
   / Grease gun chucks #1
Kendrick
Vermont
DK45S(Cab)
I have been having an interesting time with my gun lately. if i loosen the chuck on the gun enough so that it is not a bear to remove from the nipple the grease oozes out between the sections. if i tighten it enough to stop the oozing it takes pliars or better to get it back off again. any one have suggestions?
   / Grease gun chucks #2
Try a different grease nipple is about all ya can try.
   / Grease gun chucks #3
I'd try a different chuck. I closely inspected several and saw major differences in how they were made. The quality of the little jaws varies a lot as does the rubber seal quality.
I finally found one that was decent after trying several different ones.
   / Grease gun chucks #4
I bought a new chuck at TSC a couple of weeks ago (OEM brand, nearly $5) that was so poorly made I ended up snapping off the first grease fitting I put it on.:mad: trying to get it back off. I returned it to them and got a fitting at Atwoods Farm and Ranch for $1.69 that works perfectly. Easy on easy off and doesn't leak.:) So higher price doesn't necessarily mean better.
   / Grease gun chucks
any sugesstions for an online purchace? not much in the way of stores here...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
