Grease Fittings
   / Grease Fittings #1
KenGod
PA
CK2610HST
I did my 400 hour service today. Changed engine/filter oil, hydro oil/filters, gas filter and greased the fittings.
The grease fittings is what I have always had a problem with. 3 or 4 of the fittings just wont take grease, it spews back out around the fitting and the gun tip. all other fitting take grease good. I have changed the fittings thinking "bad Fittings" but still no go on the grease intake. Anyone else have this problem with some of there fittings?
I also found out today when I changed my engine oil that they gave my a filter for a ck25 last time I changed my oil. The filter this time was allot smaller so I brought the new one and the old one to my dealer to figure out what was up. My dealer said it was ok, it was a filter for a ck25 and the ck25 filter just has more filtering capacity, otherwise is the same. I was happy to here that.
One more question, after I did my oil change this time and I started it up the engine revved up and allot of smoke came shooting out of the exhaust pipe I quick hit the fuel shut off and she shut down, I double checked everything and all was good, I restarted and It ran normal. Any ideas what that was all about? I dont remember that hapening on the over oil changes I did.
Ken
   / Grease Fittings #2
Wow! Sounds like you left bumped the throttle up while the engine was off. Either at the dash or on the pump. I have never in 7 oil changes had an engine rev up upon restarting. I have seen people that like to start a diesel with the throttle at something other than low idle and when the engine starts it makes white smoke from all the fuel.
   / Grease Fittings #3
wonder if it's possible you got some oil into the intake, unlikely for sure, but sounds like other than full throttle like prior poster prognosticated (correct word?).
Oil in intake would result in what you stated.
Which grease fittings are giving you trouble? Sometimes if the joint is bound up it will not take grease, I run into this on my bucket sometimes, I move bucket and fitting will take grease.
Joel
   / Grease Fittings #4
Maybe "diagnosed" would be better. Prognosis is good however.:)
I have also had battles with grease zerks. Sometimes crud blocks the grease, sometimes there is too much pressure on the pin or axle to allow grease to get in. I bought one of those zerk fixer thingies from AgriSupply that basically just allows you to put a light weight oil into the fitting under pressure (mallet) and that has actually solved a few of the zerk problems I had. I presume the high pressure low viscosity oil is just clearing out old grease or dirt as after using it the zerk usually works fine. It hasn't worked in every case (no effect on the difficult axle zerks on a CK20 for example--better to unload the axle). It also hasn't worked on one sticky zerk on my backhoe but I haven't taken that apart yet to see what the issue is.
   / Grease Fittings #5
Ken
If you filled the crankcase via the tappet cover it is possible that some oil leaked past the exhaust valve guides and into the cylinder causing the smoke .
   / Grease Fittings
Iron horse , you could be right, I did pout the oil in a very high rate. only did it that one time for 3-5 sec.
The fittings are 3 of the 4 where the bucket attaches to the loader arms, another one is under the ck at the front axle pivots on the frame and almost every one on the backhoe arm.
Ken
   / Grease Fittings #7
Ken
First, the front axle zerks are difficult to fill on the CK and it is easier if you lift the weight off the axle using the loader.
The others are pretty routine to fill however so I am wondering if you have trouble with almost all of the zerks on the FEL pin mount and all the backhoe zerks that maybe there is a problem with your grease gun or fitting. Have you used it successfully on other grease fittings? Is it tight enough on the Kioti zerks? Was there a prolonged time when there was no greasing so that grease may have "dried out" and clogged the zerks?
If it were me, I'd pull off a couple of the zerks and clean them then reinstall to see if that fixes the problem. Otherwise it really may be the grease gun fitting I'd think.
Although those 'zerk fixer tools' are not cheap (about $40 as I recall from AgriSupply), it is a nice thing to have around the barn. I find it particularly useful for my 4n1 bucket which has a couple of zerks that always get jammed into the dirt. I can usually clear them in a minute or two rather than having to remove them for a complete cleaning.
   / Grease Fittings
I can get grease in the other fittings, all the upper loader fittings, ball joints, throttle, etc
ken
   / Grease Fittings #9
I have more problems with those bucket zercs than any otehr and the reason is that they are recessed into the bucket. The recess around the zerc fills with dirt and debris and makes it very difficult to get the grease gun all the way onto the zerc. The gun feeds grease much easier if it is all the way on or all the way off of the zerc. I use a small screwdriver or piece of wire to clear out around the zerc.
Another thing I did a year or so ago was switch to the buttery amber grease instead of the toothpaste red or grey grease. It is thinner so goes in easier. Still meets spec though.
   / Grease Fittings #10
Highbeam said:
I have more problems with those bucket zercs than any otehr and the reason is that they are recessed into the bucket. The recess around the zerc fills with dirt and debris and makes it very difficult to get the grease gun all the way onto the zerc. .
I've had that issue too. I routinely carry a small flat screwdriver with me to clean out the accummulated goop which does help.
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2004 Fleetwood Wilderness Travel Trailer (A50324)
2004 Fleetwood...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
