Grease fittings size
   / Grease fittings size #1
Clydesdale#2
Kubota
What size are the Grease fittings on a del morino funny top 132 flail mower?
   / Grease fittings size #2
Can't tell you the exact size, but being built in Italy you can pretty much bet they are metric. About any parts store, or farm supply store should have them. From TSC to Auto Zone, even Harbor Freight carries them. If you can remove one to compare size would probably be best.
If it has different sizes in different locations, they have assortment packs with different sizes and angles.
   / Grease fittings size #3
100%. Go to Harbor Freight or the auto parts store & get the $30 assortment of standard zerks & the $30 box of metric zerks. You'll only need a couple now, but they will last for years. So nice to just replace one with one on hand than to fight a damaged or clogged one.
   / Grease fittings size #4
I'm a big advocate of the HF assortments as well. When you run across a problem like that it's far easier to just go to the shelf and get the part than have to make a special trip or put it aside until you're out and about to source one.
   / Grease fittings size #5
If you try to install a zerk that is almost the same, you could ruin the threads. Find a zerk thread gauge online or store. I have one that I bought from Amazon.
   / Grease fittings size #6
Could be BST (British standard thread) too. Won't find them at TSC......
2021 Kubota RTV-X900 4x4 Utility Cart (A46684)
2021 Kubota...
2012 Buick Enclave SUV (A46684)
2012 Buick Enclave...
More info coming soon! (A46683)
More info coming...
2006 John Deere 650J LGP Crawler Tractor Dozer (A46683)
2006 John Deere...
2024 OTHI Mini Excavator (A46683)
2024 OTHI Mini...
2012 Vermeer BC1000XL Towable Brush Chipper (A46683)
2012 Vermeer...
