Grease fittings on LS G3033H
   / Grease fittings on LS G3033H #1
rjfoster
North Carolina
LS G3033H
Was having "fun" trying to remove the grease gun coupler from the fitting on my G3033H, but see that it uses ZERK fittings. I see from earlier posts that some are recommending the LockNLube coupler, so I will get that. Two questions that I have:
1. Recommendations on a grease gun (not wanting to spend the money on a cordless version).
2. What sized ZERK fitting is on the front end loader? I want to have some spares and would like to get some ordered.
Thanks for any suggestions / help.
   / Grease fittings on LS G3033H #2
For zerk fittings I bought a metric assorted pack from harbor freight or tractor supply. And then just restock the ones I use most. Between backhoe and loader I use several sizes.
As for grease gun, I invested in the dewalt battery operated gun and lock lube fitting. Many happy returns.
   / Grease fittings on LS G3033H #3
I've only had to replace one zerk on my tractor so far and it used a 1/8in NPT fitting
Amazon.com: Performance Tool W54241 1/8" NPT Grease Fitting, (Pack of 1): Automotive
I cannot imagine LS using different size grease fittings for all their tractors, but maybe. I would suggest getting something like an assortment pack such as this:
Amazon.com: Neiko 5463A Hydraulic Grease Fitting Kit, 11 Piece Assortment (SAE Sizes) | Includes Straight and Angled Zerk Fittings: Home Improvement
I find that different implements use different sizes and angles. I got this assortment pack and its good.
As far as the lock n lube, I use the longer one, the XL, just to make life a bit easier. But the short one works well too. I dont have a cordless DeWalt one yet, only because of the price. But after greasing my backhoe, I start cursing my manual one. I will likley get the DeWalt before too long. In the meantime, this is the manual one I use (or one like it):
Amazon.com: Slippery Pete Pistol Grip Grease Gun Cranks up to 6 PSI-Lubricate Tractors, RV's, Cars, PTO Shafts, Steering Cylinder, Universal Joints, Suspension Tie Rods, Ball Joints, Chassis and Drive Shafts: Automotive
Here is the lock N lube I have:
Amazon.com: LockNLube Grease Gun Coupler XL - Extra reach for recessed grease fittings: Home Improvement
Also, check out the video I did on it here:
Tools, Techniques, Tips 'N' Tricks - Episode 1 - YouTube
Hope this info helps!
Avenger, I appreciate the detailed information and examples of what you are using. I went and ordered the fittings kit and the LockNLube. I see that the grease gun that you have is no longer available, but will find something similar. Info definitely helped!
Appreciate your response and recommendations.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
