Grease fittings on BX
   / Grease fittings on BX #1
JimMorrissey
Veteran Member
Southern Maine (now)
'05/'06 L39 TLB
Can anybody detail exactly where all of the grease fittings are on a BX?.....not the loader and not the hydro pedal...got those. There must be some on the drive shafts, or up under there somewhere. I couldn't find any listed in the Kubota manual.
   / Grease fittings on BX #2
The mower and the FEL have many, but the tractor itself only has the one on the hydro pedal, believe it or not. I've looked hard and not found any other.
   / Grease fittings on BX #3
Like Charliebrn said there is only the one on the hydro peddle and that is all there is on the tractor its self.
I thought I remember seeing one on a U-joint at some point......guess not. Thanks.
   / Grease fittings on BX #5
Are you thinking of the fittings on the shaft for the mower deck? I believe there are a couple on there.
It's worth using the manual to check out where the zerks are on the deck - easy to miss one when mowing season starts and the deck isn't spotless between cuts.
Patrick
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
378801 (A51572)
378801 (A51572)
198367 (A51243)
198367 (A51243)
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
2019 FORD F-250 SUPER DUTY (A52472)
2019 FORD F-250...
