Loader Grease Fittings for T1003 Loader
   / Grease Fittings for T1003 Loader #1
4Papa
Bronze Member
Central MA
TYM T1003
Anyone happen to know the size of the zerks for the T1003 loader (LT900)? Due to their recessed location in the loader arms, I snapped off a few while greasing this past weekend. I figured they were a standard size but that doesn't appear the case. The stock zerks fit a 10mm socket but replacement 10mm fittings that I purchased both locally and via Amazon are too big for the socket. My selling dealer has no clue. This model loader also was used on the T903. Thanks.
   / Grease Fittings for T1003 Loader #2
Same zerk fitting is on my LT500 loader, if you go the TYM route. 10 mm hex on a 10 mm tapered thread, definitely a rare combination. Ended up going to local heavy equipment supply place. They had one that fit.
I broke the zerk while trying to remove the grease gun end. Not enough room to move it off axis in the recess. Replaced the grease gun end with a Lock 'N Lube grease coupler to avoid breaking more. It just barely fits into the recess, need to push the sleeve in, on a couple to connect it. Once on, easy to grease, much easier to release the zerk when done.
2024 JOHN DEERE 3039R LOT NUMBER 58 (A53084)
2024 JOHN DEERE...
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
