Grease Fittings - DK40SE
   / Grease Fittings - DK40SE #1
gkh7890
SW Ohio
DK40SE HST
Hey Pack,
Does anyone know the exact size of the grease fittings (zerks) for the DK 40SE? I have 4 that are bad. Still waiting to hear back from my dealer about getting replacements but figured I'd throw this out and see what feedback I got.
I used a 10mm socket to remove them. But when I tried a 10mm fitting from TSC, it was too big and the 8mm was too small. I'm thinking these are proprietary? I did clean them out, exercised the pins but no success in getting them to work.
Thanks!
   / Grease Fittings - DK40SE #2
1/8 pipe thread zerks are what we replace with. Typically a 7/16 nut driver is what you will need. Don't ask why - I don't know either. FYI: Occasionally you will run into a press fitted zerk. Pull out and tap to 1/4 - 28.
Tony
   / Grease Fittings - DK40SE #3
Tony
Fastenal carries 1/4-28" self-tapping zerks.
Steve
Steve & Tony,
Thanks for the information. I'll give it a try and see what happens!
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A50322)
2023 Caterpillar...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50323)
2015 Eager Beaver...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
