Grease fitting on GC2610
   / Grease fitting on GC2610 #1
Rob2310
West Virginia
GC 2610
While installing the upgrade for the HST Pedal Return (Neutral), I attempted to grease the fitting that is located between the HST Pedals. It would not take grease. I changed the grese fitting and still no luck. Has anyone else had any problems greasing this fitting?
   / Grease fitting on GC2610 #2
Pull the fitting back out and see if the hole goes through to the shaft. I had one on the BH that did not go through. After drilling it out it worked fine.
Doug
   / Grease fitting on GC2610 #3
Yeah, call that dealer that is getting paid to put the kit on & tell him to fix the grease fitting too.
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
