My BearCat 73454 PTO chipper has two grease fitting that are difficult to impossible to reach, so I'm thinking of adding extensions to bring the fittings out where they are easier to reach.
One is under the belt guard, which is a pain to get off. I'm thinking that a simple pipe extension running up through a hole in the sheet metal to bring the fitting into daylight would do the trick. But I've not been able to locate extension pipes. Maybe I don't know what they are called?
The other was provided with a right angle fitting and a hole in the frame that is supposed to let you grease it. But I've never been able to get a grease gun on it through the hole, and now in a misguided attempt to adjust it I've let it fall off. I can't re-install it because I can't reach my hand in behind the belt pulley, and getting the pulley off looks like a terrible task, and wouldn't fix the issue anyway. So I'm thinking an 8-inch or so extension hose to bring it out beyond the belt guard would do the trick. I see a number of online sources for such hoses.
The fitting that came off is threaded and looks to me like it might be 1/8" threads. Any reason to think it might be something else? Can I measure it to be sure?
Anyone have any experience adding such things? Can you suggest sources of supply (online -- unless Lowes "hardware" carries it I won't find it in the county).
