Grease Bearing Kits
   / Grease Bearing Kits #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
I have a very large condeser with two 15 horsepower motors on it. My problem is there is two blowers on it with 3 pillow block style bearings. One of which I can not get to so I can grease it. I know there is kits out there with hoses on them so I can take the grease sirk out and run a hose out to where I can get a grease gun.
I have tried Tractor supply, Menards, Fleet Farm, Grainger and two bearing places here in town and everyone knows what I am talking about but doesn't have access to them. I even tried some of the implement dealers and they won't order one without a model of an implement?? Anybody out there ever purchase a generic kit?? and where.
Murph
   / Grease Bearing Kits #3
How about a small brass adapter on each end of a flexible brake hose with a zerk fitting on the outboard end. This seemed to be the way an old 2 row cornpicker I had was rigged.
   / Grease Bearing Kits #4
Use a fitting with the same thread as the grease zerk, Screw it in, attach a piece of tubing or small black pipe ending in a fitting that will accept a grease zerk in a location that is easy to access. Tubing could have compression or flared fittings. the black pipe would be threaded.
You could do the same for the rest and have them all come out to a common location and do all the greasing from there. This is not an uncommon practice.
Egon
I guess I could make one. I just thought I could buy a kit and get it done today. The job site is 2-1/2 hours away. So I will just make one with a compression fitting and flexible hose.
murph
2011 Chevrolet Traverse 1LT SUV (A50324)
2011 Chevrolet...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2020 FREIGHTLINER...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2012 Chevrolet Cruze Sedan (A50324)
2012 Chevrolet...
