Grease and a better understanding of it
   / Grease and a better understanding of it #2
Good info, thanks.
   / Grease and a better understanding of it #3
Just one thing it did not mention is that you cannot mix greases i.e. those that are Lithium based are not to be mixed with clay based grease.
When you mix they turn back to oil and will wreck whatever you wanted to protect
   / Grease and a better understanding of it #4
Not only that, I can cause corrosion. That is what happened to some aircraft. The Boeing 767 Landing Gear trunnion mounts is one example.
Retired Airline Mechanic
Tom
   / Grease and a better understanding of it #5
It was a good article. What it didn't explain is the difference between Lithium Complex and others. Tracter mentioned clay based greases, which aren't compatible with any other thickener. The article also didn't address strengths and weaknesses, basic construction, emulsification or reversibility. All of those are important for a purchasing decision.
   / Grease and a better understanding of it #6
Grease is maybe not the word , the word is "Knowledge"
"COMPATIBILITY?" OMG I never thought about that. Now I'm in a small panic. I guess shopping around to save save a couple of buck or just for the convenience when purchasing definitely takes back seat.
It also stresses purging the old grease as much as possible. Below is a additional info on grease and compatibility.
The Skinny on Grease Compatibility
Why don't the mfg's of the equipment state this?
   / Grease and a better understanding of it #8
So I guess the best thing to do is pick just one type of grease and stick with it. Can anyone recommend a grease that is not expensive but can be used for backhoe and loader zercs along with mower deck bearings?
   / Grease and a better understanding of it #9
CRC/STA-LUBE Sta-Plex Premium Red Grease (NLGI #2). It is available in tons of places, has excellent water washout resistance, and is an EP (extreme pressure) type.
SL3190 -- Sta-Plex™ Extreme Pressure Premium Red Grease, 14 Wt Oz
[ame=http://www.amazon.com/SL3190-Sta-Plex-Extreme-Pressure-Cartridge/dp/B000KKJRMW]Amazon.com: CRC SL3190 Sta-Plex Extreme Pressure Premium Red Grease, 14oz Cartridge: Industrial & Scientific[/ame]
Wrooster
   / Grease and a better understanding of it #10
Now we're back to topic. All Lithium Complex greases emulsify with moisture. Manufacturers use polymers to prevent wash-out reducing the percentage making it appear to the public it performs well. The polymers they use also raises the dropping point, however, the more polymers the less amount of oil. Oil is the lubricant.
Furthermore, water is heavier than oil. Basic Jr. High School science. As moisture emulsifies the Lithium it displaces the oil reducing the lubricating ability of the grease. Increasing grease consumption and metal wear. So that "cheap" grease your using is costing you much more than the price of the tube.
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
2002 MACK RD688S ROLLOFF TRUCK (A51406)
2002 MACK RD688S...
2016 CHEVROLET 3500HD SERVICE TRUCK (A54756)
2016 CHEVROLET...
John Deere 853 20ft Corn Head (A55301)
John Deere 853...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
