Greasable equipment bushings
   / Greasable equipment bushings #1
SuperDuty335
Lincoln County, NC
Hello everybody. I've done a lot of searching and can't find exactly what I need. I would like to know where to get the pre-assembled, greasable bushings like what Markham uses on their grapples. Their website shows them clearly on their grapples with the grease zerk in the end of the bushing. Any ideas?
Thanks Jake
   / Greasable equipment bushings #2
I just drill my pin and then cross-drill to intersect the end drill. Kinda "L" shaped from the side.Put the zerk on the end of the pin.
   / Greasable equipment bushings #3
Thank you for this idea.
After the painting is done (not even started yet), I will fix up all the pins on the loader.
I would go ahead and do it now, but that would just be more grease to have to de-grease.;)
That's the method I know, but I thought you could buy everything pre-fab. and just weld it in place.
   / Greasable equipment bushings #5
I am looking for the same thing and have searched to no avail. It seems as though it would be a common item but I guess not.
   / Greasable equipment bushings #7
call the company and order there pins from parts, if you want pre made.
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2005 Honda Foreman 420 (A50123)
2005 Honda Foreman...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
