Frankenkubota
Veteran Member
- Joined
- Jun 11, 2020
- Messages
- 2,386
- Location
- Carthage NC...Deep in the woods
- Tractor
- Kubota MX 5800, SkidPro 4 in 1, Ratchet rake, SkidPro pallet forks
I bought it used with 10 hours on it. Original owner said he didn't like the controls and already had a new lawn tractor in his driveway.
I know nothing about many things so I took a friend who works on lawnmowers. When started, I immediately thought the engine ran at a too high RPM but both the owner and my buddy said it was due to emissions. Ok
The throttle control lever was very tight so during one of our monsoons, i pulled it apart to look see. The choke and throttle levers both mount to and revolve around a rivet and are adjusted by steel cables. The choke was fine. I could barely move the throttle cable by hand, something was wrong.
I could tell none of the hardware had been messed with, no wrench marks or scratches etc. I think my problem was due to assembly errors? I worked on the assembly line for years, at a number of places. You do not want to buy anything made on second shift after lunch!
Long story short, I took the throttle cable off, readjusted it and believe it or not, it worked!
I now have lots of adjustment range and at a lower rpm, the controls are much less twitchy.
I noticed the body parts are all SAE while the kawi engine hardware is metric. I still think that's just crazy and very wasteful! I also noticed they used a lot of self taping screws. They are fine unless the assembly guy/gal puts them in at an angle, which of course they did.
