Gravely ZTR Electric Clutch Removal
   / Gravely ZTR Electric Clutch Removal #1
kubota06
South East Texas
Kubota L3400
Any One with experience removing an replacing electric clutch on The ZTR's
Model 996024 144Z Series
I need to replace engine bottom seal an can't figure out how to pull the upper half of clutch off shaft.
Kubota06
   / Gravely ZTR Electric Clutch Removal #2
Horrible Freight has a hydraulic gear puller if you have the room for one. Used one on a 20hp horizontal shaft onan.
I'll give a look an see if it will fit .
There is just the cast aluminum clutch housing and don't think that could withstand the pull. Other than that. Hopefully someone might know if there is a specialized puller. Local Dealer ship $65 hour. I could probably afford the tool more than their labor bill.
   / Gravely ZTR Electric Clutch Removal #4
Worked st a Gravely dealer, we just used an air hammer to remove them. Spray crank shaft and work if off. Keep rotating it as you hammer it. Puller won't work since clutch has a rounded edge and puller slides right off!
Thanks Topside
I've got it up on jack stands I'll give it a try
I did see on YouTube were 1 man fabricated a heavy duty cusrom "C" Shaped puller. If all else fails I may seek that avenue with a cousin who fabs.
Sorry TOPZIDE realized I misspelled your Handle
   / Gravely ZTR Electric Clutch Removal #7
Unfortunately many times the clutch isn't a good candidate to use a puller on and they come off in pieces. MTD had an interesting approach which was to start the engine with a loosened retaining bolt. I've got a homemade c puller made out of plate that I destroyed earlier this summer.
Mower 16yrs old no way that clutch is coming except in pieces. Getting back on that project today.
   / Gravely ZTR Electric Clutch Removal #9
Spray penetrating oil on it 3, 4 times a day for a week. Tap the crank shaft and clutch from time to time. It will come off.
AND when putting it back on, use lots of anti-seize on it.
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
New Holland C238 Compact Track Loader Skid Steer (A52377)
New Holland C238...
Pair of New 700/40-225 Alliance Tires with Rims (A53473)
Pair of New...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2020 CHEVROLET SILVERADO (A53843)
2020 CHEVROLET...
RoGator RG1100C (A53473)
RoGator RG1100C...
