Gravely Super Convertible comes out of gear
   / Gravely Super Convertible comes out of gear #1
Samandothers
Charlotte NC
Kubota L4240
I have a 72 or so Super Convertible. After running about a 30 to 45 minutes and getting hot the Tractor will slip or come out of gear, usually the high range. I usually shift into low and can continue but slower.
Ideas as to what the issue may be?
   / Gravely Super Convertible comes out of gear #2
I'm bettiing that it has the 2-speed axle and the Clutch Housing on the Worm Gear is worn or the Sliding Clutch is worn. Or Both.
Fladon, You are correct it is a two speed axle. Is there a website with some info on the fix and is it a difficult repair? I did not see much here. Thanks for the reply.
   / Gravely Super Convertible comes out of gear #4
olldgravelys dot net
Replace the dot with a . Under the manuals you will find the manuals for the Ls and Cs. The job isn't that hard, but neither is it a cheap fix to do if you want it to be long term. You pull off the right axle housing after draining the oil out of the tranny/engine combo. Drain bolt is the bottom one on the left side axle housing where the housing is held to the tranny case. With the engine and tranny supported, you then pull the left axle and housing if the ears on the Clutch Housing are rounded. The diff section will drop down in the tranny and come out the right side. There are 6 bolts that hold the Clutch Housing to the Diff. The Clutch Housing also has a taper roller bearing that has to come off. To do a cheap and dirty repair, you grind the ears so they are perpendicular to the bottom, back to the point where there is only a little curve at the outer end. That means 3 to 6 edges need ground or filed. To do a long term repair, you replace the Clutch Housing and Sliding Clutch. The Sliding Clutch is steel whereas the Clutch Housing is Cast Iron so the wear takes place there.
Fladon
Guess I have a decision, continue to use as is, do the 'dirty' repair, or do it right. May live with it for now. I use the tractor only a couple of times a year to mow some area in my back yard. Don't till with it anymore.
Thank you for your response.
   / Gravely Super Convertible comes out of gear #6
You probably just need to adjust the linkage. My 12 hp Gravely would do this if the linkage was a little out of adjustment.
Ralph
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2013 F-550 Bucket Truck (A53473)
2013 F-550 Bucket...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
