Gravely Model L Starter Switch Problem
   / Gravely Model L Starter Switch Problem #1
b brown
Henderson, ky
Gravely Model L
Hey Guys, I've got a 1972 Gravely Model L with an electronic start that ran great last year but the starter switch needed replacing. I had the spark plug unplugged and took the negative wire off the battery while I put in the new starter switch. There are only two wires to the starter switch and everything looked okay when I put it back together but when I put the negative terminal back on the battery post, WHAM! Sparks flew and even took a little chunk out of the terminal! So, I guess I've got a short and it must have something to do with the new starter switch but I don't see anything obvious. Does anyone have an idea what I'm doing wrong here? Thanks -- BG Brown
   / Gravely Model L Starter Switch Problem #2
by some chance is the battery post reversed if this is ok then try running new wires to hook ups from starter switch and starter solenoid and key switch
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
RIDGID K-400 POWERED DRAIN CLEANER (A51248)
RIDGID K-400...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51692)
2022 Big Tex...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
