gravely 817 oil light
   / gravely 817 oil light #1
spatrx
My oil light stays on even tho full?Any suggestions or fixes?could the filter be clogged?I just ran it for a while and it stalled out.any help out there?
   / gravely 817 oil light #2
Oil lights are often confused as level indicators. They are not. They are pressure indicators, usually set at very low pressures such as 2-5 psi before they light. My guess is that the filter is clogged or media collapsed, or the pickup screen to the oil pump is plugged.
Running with little or now oil pressure will toast an engine. I'd look this over very carefully before trying to run it again. Did the engine run fine before it stalled? Or did it sieze?
yeah it ran ok I don't think it seized i can stil move the fly wheel.I'll try the filter.
put new filter on, light still on, engine not seized,is this screen internal?,i dont see the cup.man this sucks,ran great last week.forgot to mention a fuse is blow back near the filter in the harness for the pressure relief valve would that have a thing to do with this and yes some wire is exposed,i just don't have a fuse yet.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
90018 (A48082)
90018 (A48082)
1969 CHEVROLET C10 SHORTBED PICKUP (A54607)
1969 CHEVROLET C10...
TMA (A49461)
TMA (A49461)
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
