grasshopper diesel how much can it do
   / grasshopper diesel how much can it do #1
JWB53
Bronze Member
07 toolcat
could grasshopper diesel 6 foot deck handle 1-2 foot grass & weeds, at a reasonable pace, i have over 40 acres thanks i'm concerned about time to cut and over heating
   / grasshopper diesel how much can it do #2
What horse power engine are you talking?What kind of terrian?I have a 2007 Kubota 326 pro ZTR 26hp diesel with a 60 inch deck that does fine job.Kubota makes a 331 diesel with a 72 inch deck and a model F3680 36hp diesel with a 72 inch deck.If I was mowing 40 acres I would buy the biggest tractor I could afford with a large finish mower or rotary cutter.coobie
   / grasshopper diesel how much can it do #3
It would take you a week to cut that with a 72" ZTR.
You need a tractor pulling a bushhog to do that kind of mowing.
   / grasshopper diesel how much can it do #4
I think your arms would fall off trying to mow 40 acres with a zero turn. While I like the Grasshopper diesel mower I would seriously spend the money on a simple utility tractor with a brush chopper or finish mower. Price wise would be almost the same but you will be a lot more comfortable on the tractor then you would on the zero turn. Plus the tractor would give you options for other attachments if you ever wanted them.
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
2015 Ford Focus (A51694)
2015 Ford Focus...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2009 Sterling AutoCrane 10006H 5 Ton Mechanics Crane Truck (A52377)
2009 Sterling...
