grasshopper 321d question
   / grasshopper 321d question #1
banshee.350
florida
new holland tc30 4x4, grasshopper 321D
I have a 321d it has about 1300 hours. I have done alot of work to it since buying it used about 3 years ago. It recently started shutting down and I don't know why. The 1st time it did it I was mowing with the blades engaged. I adjusted all the belts thinking maybe this could be a contributor. But then yesterday it did it after I started it and went to full throttle. It did this a couple of times and then it ran fine. It also sounds like the pto clutch is disengaging and reengaging while I am mowing. The clutch and pto switch are only about a year old (all oem grasshopper parts). Looking at the voltmeter it shows about 12volts at idle and just over 14volts at full throttle. I am going to change out the fuel filters and see if this helps (they aren't that old) but if anyone has any other ideas I would sure appreciate any advice. I don't want to end up at a grasshopper dealer chasing a gremlin
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2022 Adams CLC-1013 Conveyor - New (A53473)
2022 Adams...
2023 G Bar K Skirted Hauler Bed (A53473)
2023 G Bar K...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
