Spreader Grass seed setting on spreader
   / Grass seed setting on spreader #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I have a pull behind spreader that has a setting for coarse or fine grass seed. Is a pasture mix with timothy and clover considered coarse or fine?
Eric
   / Grass seed setting on spreader #2
I'm not familiar with tim/clover seed sizes.. However.. compair them to bahia and centipede. Bahia is like sesime seeds on a burger bun.. those are coarse. Centipede is like grains of salt.. those are fine.
Soundguy
Thanks Soundguy, that now gives me a relationship I can judge by.
Eric
   / Grass seed setting on spreader #4
I ran 150 lbs of perennial ryegrass and some tall fescue through a hand held whirly bird over the last couple of weeks. Fescue seeds are large, ryegrass seeds are much finer, clover seeds are super small.
I would suggest seeding a measured area and checking lbs per acre that way.
The fescue seed doesn't feed as well due to the large seed size.
   / Grass seed setting on spreader #5
I ran Zoysia seed through a walk-behind spreader and found that the seeds were so small they began to run out with the setting at "0", for small seeds think about mixing with sand or some other larger granules, or putting an inch of sand in first with the seeds on top.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2018 International DuraStar 4300 26FT Box Truck (A55852)
2018 International...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2017 KENWORTH T680 SLEEPER TRUCK (A56138)
2017 KENWORTH T680...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
