Grass Seed Question
   / Grass Seed Question #1
Shemp
I'm wanting to spread out some grass seed on certain areas of my land. I'm down here in Columbus Texas and was thinking of using bermuda. Any thoughts on other types would be apprieciated. thanks.
   / Grass Seed Question #2
I'm not sure about your region of the country, but Buffalo Grass is a pretty hot item for many people. It grows slowly and never gets much more than 3 inches tall.
Good luck
   / Grass Seed Question #3
You should contact the Texas Cooperative Extension agent in your county, they will come out and make recommendations, I have also used the USDA agent for the same purpose.
The USDA in Decatur TX also sells seed for our local area.
You can research alot also on the net on thier respective homepages
Texas AgriLife Extension Service
   / Grass Seed Question #4
I've also had pretty good luck getting advice from the local co-op. They pretty much know what everyone is using.
   / Grass Seed Question #5
Bermuda is a warm weather grass, with all sorts of varieties. Some can be started with seed, others need spriging. The grass seed needs 80 degree temps to germinate. You can buy hulled or unhulled. Hulled will start faster, but you have to have ideal conditions for it. Unhulled will sit and wait for the weather, but takes longer to germinate.
You need to decide what you want to grass to do. Hay? Pasture? Lawn? or just look green?
I'm planning on planting a field that I'm working on in a few months. First I'll go to the Ag Extension and pick up some sample bags. You fill them up and send them off to analyze the soil. It's about $10 per bag, and they will tell you exactly what your soil needs.
Be sure to look at the labels on the Bermuda when comparing prices. Most of the seed that I've seen is only 50% seed in the sack. That means half of what you are paying for is not seed. If you buy a ten pound sack of seed, you actually only have 5 pounds. Be sure to figure that in your math. Bermuda seed seems to be going for about $6 a pound at the box stores. I haven't priced it at my farm store yet, but have found them to be cheaper in the past.
As for other types of grass, it really depends on what you want it to do? Centepede is my all time favorite for a lawn or lanscaping. Once you get it going, it's a beautiful green and it grows so slow that you only mow it once or twice a year, if at all.
I've never tried buffalo grass, but from what I've read, it's amazing stuff if it will grow in your area. I'm thinking of buying a small bag and seeing how it does. I like the idea of having a variety of grasses in my pasture, but mostly I have bermuda and bahia.
Bahia is very aggressive and does great in my area of East Texas. Unfortunately, it grows these ugly stalks that can be several feet tall. Two days after you mow, the stalks are already severel inches tall again!!
Eddie
   / Grass Seed Question #6
Seed is expensive as is fertilizer this year. Eddie’s advice on doing a soil test to see what is needed to make that expensive seed grow is good advice. Bermuda is slow to establish but once it does it is almost unstoppable. Don’t get discouraged if the first year does not give you the results you are hoping for. It can take several years to establish. Bermuda likes to be planted in hot weather. If you are planting an area you can not water be like a farmer and pray for rain after you seed.
MarkV
   / Grass Seed Question #7
Bermuda seed is very fine and can go a long way. I have about 60-70lbs I plan on spreading in a few weeks. I have been told to mix the seed with sand before spreading. Any idea on the amount of sand needed per pound of seed?
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A50322)
2022 Caterpillar...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
Kohler 50 Generator (A50774)
Kohler 50...
2021 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 Kubota...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
