Grass growing up through mulch
   / Grass growing up through mulch #1
Chiege
SE Ohio
MF GC 2300
Hi all,
What are some recommendations to kill grass and not flowers, plants, shrubs, etc...?
Thanks,
   / Grass growing up through mulch #2
I watched a landscaper last summer spraying the mulch around the bushes and flowers. He said that he used a dilute solution of Round Up to keep the weeds from starting. Seemed to work, because I didn't see any weeds or grass around the shrubs or flowering plants. I believe that you have to get it on the leaves to kill the plants, so be careful where you spray and don't spray on a windy day.
   / Grass growing up through mulch #3
If your weeds are in tight quarters with the bedding plants then take a plastic bottle and cut the bottom of and spray in through the top while covering the weed. Yep lot of work, it might just be easier to pull the weeds.
   / Grass growing up through mulch #4
Hula Hoe them. Fairly quick and simple.
There are herbicides you can use too, that will kill grass but not ornamental plants.
Here is one Grass Getter
   / Grass growing up through mulch #5
I bought one of the plastic spray bottles of Round-Up with a nozzle you can turn for a "stream" or "foam" and that's what I use. Of course, the "ready mix" is expensive, so I just keep refilling that spray bottle from a bottle of concentrated Round-Up and water. It's pretty easy to concentrate it on just the plants you want to kill without getting the adjacent plants.
Bird,
Yep, that's what I've been told is the best and quickest way to go about business.
I am concerned that if I spray to kill grass, then want to plant something in the same area, there may be some of the poisons hanging around in the soil.
My thumbs are far from green, so anything I plant will probably die anyway, hehe.
   / Grass growing up through mulch #7
I have had more manageable results if I put newspaper down
before I mulch. Yes it can be time consuming in flower beds, but it really works out well for me. Anything undesireable coming up is easily removed.
-Mike Z. /forums/images/graemlins/grin.gif
   / Grass growing up through mulch #8
<font color="blue"> I am concerned that if I spray to kill grass, then want to plant something in the same area, there may be some of the poisons hanging around in the soil.
</font>
RoundUp kills by being absorbed into the leaf -- it's not a pre-emergent, so it won't prevent anything from growing if you've sprayed it in places.
   / Grass growing up through mulch #9
</font><font color="blue" class="small">( <font color="blue"> I am concerned that if I spray to kill grass, then want to plant something in the same area, there may be some of the poisons hanging around in the soil.
</font>
RoundUp kills by being absorbed into the leaf -- it's not a pre-emergent, so it won't prevent anything from growing if you've sprayed it in places. )</font>
It also goes inert as soon as, or shortly after, it touches ground. There is no residual effect.
Harry K
Thanks to everyone for the info. I believe I have an idea of what direction to go.
Ditchwitch 1030 Walk Behind Trencher (A50121)
Ditchwitch 1030...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
Assortment of Pipes (A50121)
Assortment of...
