Grass & Drought
   / Grass & Drought #1
BXmark
Bronze Member
BX2200
We have not had a drop of rain here in my area of S.W. Ohio in 9 weeks coupled with 10 straight days of over 95 degree heat. All the lawns are completely brown. I'm worried my almost 3 acres of lawn is not going to make it. How long can lawn grasses survive with no water?
   / Grass & Drought #2
until it dies !!!
but seriously, most grasses are pretty drought tolerant. The browning is just the grass plant preserving the roots ( the life of the plant ). all of the available moisture is shunted to the roots and the plant all but goes dormant. the key is not to stress it.
my rule...if your gonna water you've gotta water all season because you spoil the grass into being water dependent with shallow weak roots. if you let nature do it, the grass will be more able to cope.
just stand-by, stay off the grass as much as possible and wait for some rain. you'll be surprized at how well it comes back...and how quickly !!!
   / Grass & Drought #3
I agree with tc35dforme.
Just let it go and do not worry about it. There is not much you can do until you get some rain.
Also, try not to drive across it with heavy equipment or have any football games or the such - another kind of stress.
I do not know how high you mow your grass, but the higher the better. We mow ours at 3.5-4 inches. This does two things. Prevents weed seed from germinating and keeps more moisture in the ground. In your situation, your grass may have keep a little greener a little longer. Since you haven't had that much rain, it may not have made much difference in the long run.
Just think of all the fuel you've saved!!! /w3tcompact/icons/shocked.gif Not much consolation to us tractor driving folks though..... /w3tcompact/icons/wink.gif
Terry
   / Grass & Drought #4
My grass turns brown every summer. My kids drive motorcycles and gocarts and such. The grass gets trampled and then it blows away. I am often left with nothing but dirt (S.E. Mich). As soon as we get some rain, it all grows back. Amazing stuff /w3tcompact/icons/grin.gif
   / Grass & Drought #5
Seems the worst that happens is that some weeds get a chance to enter into the world during this time of no competition. That is one reason I always plan (doesn't always happen tho ) to spray herbicide (2-4d) in the fall, after the rains come and the grass gets green again.
   / Grass & Drought #6
mark,sorry to hear of the drought and your poor lawn,if your grass is fairly new seeding,you might have some problems.If your lawn is established,and has a decent root system,it will be O.K...We have been very lucky and have had rain when we needed it.
I can recall the Summer of 80' when we had NO rain all season and 100+ temps. for 18 days straight,when the rain finally came,the grass greened up and started growing again.
   / Grass & Drought #7
My grass is brown every place except over the septic laterals, near my trees and my wife's flower gardens where we water.
   / Grass & Drought #8
Not trying to rub anyones nose in it,just wanted you all to see how lucky we have been this Summer with the rain.Infact,we just had a shower last night.
   / Grass & Drought #9
We live outside of Louisville, KY and haven't had rain in about the same amount of time. The Ohio Valley is is unusaually dry. I agree that you should let nature take it's course. If you water the grass will get shallow roots. If you don't the roots will go deeper. As soon as it rains it will green up again, and it will someday, right? I have 6 acres so all I'm doing is keeping the schrubs watered.
   / Grass & Drought #10
I picked a really bad year to start new lawns! I put in an above ground pool and had to do some major landscaping. We haven't had an inch of rain for 2 months!. I know I should be watering deeply, but I am affraid to run my well dry. So I give each section about 15 minutes/day on the sprinkler. It takes about 2 hours. I just don't want it to die. The seed is expensive.
2005 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
78'' skid steer bucket (A53421)
78'' skid steer...
