Grapples in stock?
   / Grapples in stock? #1
flashpuppy
Triad, North Carolina
Kubota M7040 Kubota SVL75-2
I would really love to get an EA Wicked 66 grapple, but I do not think I can wait eight weeks... I need to get some stuff done and putting it off until the end of January is not an option.
Who has some good grapples for an M7040 in stock?
   / Grapples in stock? #4
Land Pride thru your Kubota dealer - - ANBO, in Colville, WA. ANBO will make anything you want - out of several different types/grades of steel and has many models in stock. I've visited ANBO a couple times - 70 miles north of me - and they make fantastic grapples.
I was just about to pull the trigger on an ANBO until the local Kubota dealer made me a great deal on the Land Pride. Also - if you will be getting a grapple, consider making some type modification - such as I did - to you grill guard. I will save your grill, battery, radiator from unnecessary holes.
View attachment 576295View attachment 576296View attachment 576297View attachment 576298
   / Grapples in stock? #5
Just picked up my LP SGC1572 (same version as Oosik, just a bit wider) yesterday. Taking it up to the property tomorrow. These are designed for Skid Steers, so they are super strong and reinforced. I went with the LP over EA because cost was same but I could get it in 2 weeks instead of 2 months. From the looks it should be an outstanding front implement. My only concern which I can see Oosik fixed with a bungee is the hoses. I will have to be careful when QA attaching (not to hit them) and find a good place to keep them out of the way.
Of note, this is a very heavy grapple. Mine weighs 900-1000 lbs. So consider the weight in your FEL lift calculations.
   / Grapples in stock? #6
Jchonline - I'm pretty sure you will like that new grapple and the way it works. I've had mine for four and a half years and have not been able to do much more than wear some paint off it. Your Op manual - like mine - covers the SGC 1560 - 1572 - 1584. It lists your grapple at 922 pounds. That 100 pounds heavier than my 1560. My favorite task - come up to a half buried rock - about the size of one of those old steel office desks - FEL up high - rotate the grapple straight down - jaws wide open - come straight down on the rock - close the jaws - pluck the rock right out of the ground. It even makes me tired to try and explain how much time I use to spend digging those rock out with a hand shovel - nudging them onto a wooden skid and drag them to my "disposal draw/valley".
Every so often I will have to fall and burn one of my old buddies - an ancient Ponderosa pine. Pine bark beetle. Those hoses flop around - I was concerned that they might get tangled with the limbs I scoop up - - so the bungee. I've got to get a new pair - the "uncovered" ones die an early death from UV. The bungees with the cloth cover seem to last a bit longer.
My bungee attaches to the bracket that the "bucket level indicator rod" slid thru. About the second week I had the new tractor - something hooked on that indicator rod - oh, well, its not an important item anyhow. The location is just right - just enough bungee pull to hold the hoses up and allow them to stretch out for all types of grapple movement.
   / Grapples in stock? #8
   / Grapples in stock? #9
Anbo is a great grapple. I’ve had my rancher series almost 2 years now and very pleased with it. Ditto what the others said about the grill protection with expanded metal, I just recently punched a hole in the mesh on my grill while planting deer food plots and not sure how as I hadn’t even been using the grapple. I’ll try to get a couple pictures of how I fixed my hose couplers. Although there is a wait for an Anbo, it’s usually only a couple weeks, but I think weather is a factor in that so I’d order now, as I had a little longer wait because I ordered in January when they were down for heavy snowfall. Contact David Floe at the Anbo Company and I guarantee he’ll do you right and you won’t be sorry you chose them.
   / Grapples in stock? #10
you can get a Titan shipped the same day you order, and anyone within 1000 miles of Memphis TN where they're located gets free shipping. No I don't work for them, I'm just a satisfied customer on a few different things. Not a grapple though.....YET.
palletforks.com is their site
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2015 Ford F-750 Stellar 10628 10,000lb. Mechanics Crane Service Truck (A56858)
2015 Ford F-750...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
