GRAPPLE
   / GRAPPLE #1
maddog2020
farmall 45
Was wanting to get a grapple for my JD 4720. I can get a really nice used Frontier av20e with dual lids from dealer for 2400. Seems like a lot guys on here brag on the wicked grapples. A new 60inc wicked grapple is $3650. Only drawback I see to the frontier is that it weighs 790lbs to the wickeds 400lbs. Any advice? Is the wicked worth the extra $?
   / GRAPPLE #2
Check out the Homestead Implements Pinnacle series as well as the Catawba grapples. I wouldn't give one red cent to EA for a wicked grapple after what they did to their customers. EA isn't the only outfit making very stout and low weight grapples.
   / GRAPPLE #4
   / GRAPPLE #5
This one only weighs 460# and is a little larger. Catawba has excellent customer service from what I have seen.
   / GRAPPLE #6
And having had both styles, I recommend the dual lid:
   / GRAPPLE #8
My EA grapple has been an absolute pleasure to own(EA pine rake has been just as good). I bought it before the shtf and didn't pay nearly what they cost today. I haven't researched options in quite awhile but I'm glad I bought it when I did. I've got about 80hrs of use so far and its still like new. Mostly using it for pine related activities. Happy Hunting!
   / GRAPPLE #9
What's your loader lift capacity? If you can lift 2,000lbs do you want to loose 800lbs lifting implement? Makes a big difference if you are trying to lift logs off a trailer. Rocks? Moving brush not so much a problem as it means you need to take smaller bites and take more trips.
   / GRAPPLE #10
Express steel and tomahawlk attachments both have 60in grapples for under $2500. Both are also USA made and I believe aboit 400lbs for the double lid.
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
Miscellaneous Office Accessories (A56860)
Miscellaneous...
2005 Chevrolet Colorado Pickup Truck, VIN # 1GCDT146258224098 (A57453)
2005 Chevrolet...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2 Tires and Rims (A57454)
2 Tires and Rims...
