Grapple Grapple weight
   / Grapple weight #1
Bspring
SC
I have a John Deere 3320 that I would like to put a Root Grapple on. I like the design of the Faver products. The problem is they are heavy and may be over kill for my tractor but I am hard on my equipment. The one that I am looking at is 619 lbs. Is that too much my my loader? I an not sure how much the stock bucket weighs to make a comparison.
   / Grapple weight #2
You'll get great advice on here from experienced operators. My opinion is that 619 pounds is way too heavy for your tractor.
I think the ideal grapple for you would be our 50" Single Lid Wicked Grapple. It is PLENTY strong for the 3320 and other compact tractors up to around 35hp, and weighs only 274 pounds(255 pounds if you remove the intermediate slats).
The heaviest I would recommend would be our 54" or 60" Dual Lid Wicked Grapples, which weigh 349 and 382.
There are other choices out there. Keep in mind that the weight needs to be as low as possible to maximize your lift capacity.
We offer our grapples with the JD 300/400 series quick attach for no additional charge.
Shipping is free to a staffed commercial business or supporting freight terminal within 1,000 miles of Newton, NC.
Travis
Here is a video of our single lid grapple in use on a CT122 Bobcat, which has less HP and a slightly smaller frame than your 3320. It is amazing what those little tractors are capable of when the attachment is properly matched.
   / Grapple weight #3
My Land Pride grapple - SGC 1560 - weighs 820#. My FEL bucket weighs - 463#. Simple math says the grapple reduces my total lift around 360#. I'm willing to accept that because the grapple is very HD and I'm not about to bend or break it.
   / Grapple weight #4
Assuming you have the 300cx loader, from what I have found, the stock bucket weighs about 210 lbs. The lift spec at the pins is 960 lbs, if you put a 620 lb grapple on it, you won't be able to lift much.
   / Grapple weight #5
This is the best bang for the buck Root Grapple style and the best price (courtesy of another poster here on TBN who shared it).
Dirt Dog 60 In. Compact Tractor Ag Grapple - McGee Farm Equipment, Inc.
Someone on TBN also mentioned that Dirt Dog has been around for many years and actually OEM stuff for some other companies. They apparently did that before starting to sell direct under the Dirt Dog name.
   / Grapple weight #6
Travis
AGREE. ... OP - you need light and strong. Fortunately narrow is usually a benefit too. EA seems to have it all covered here with use of hi strength steel and selective drilling to preserve strength while minimizing weight. Also there is almost no benefit to multiple jaws and youre always stuck with their extra weight and profile.
larry
   / Grapple weight #7
My tractor is similar in size to the Original Posters, If not a little larger, and a little more lift capacity I think, and I have the EA wicked 50 inch single lid.. It works well for me. I like its light weight and strength. Everyone's needs in a grapple is not the same of course.
   / Grapple weight #8
I just sold a 73 inch heavy grapple that I used on my L4600 because it was so heavy made it unstable when lifting loads high. I am looking at the 60 inch wicked grapple with dual clamps but I don't use mine as a root rake I just load brush with it.
   / Grapple weight #9
Should be about 400 lbs more than that at the pins, and about 1000 lbs 500 mm forward of the pins. I do agree that a 620 lb grapple is too heavy for a 300cx
   / Grapple weight
Okay, you guys have convinced me. I want as much lifting power as I can get. As I said, I am hard on my equipment and I have really beat my bucket up. That was the thought process behind getting something heavy but I would be more upset about it not being useful than having to work on it every once in a while.
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
John Deere 7410 (A53317)
John Deere 7410...
