Grapple Build, suggestions for bushings
   / Grapple Build, suggestions for bushings #1
willysmb
Bronze Member
Grand Rapids, MI
Massey 1736
I am going to be building a grapple for my new tractor. When it comes to plate steel I have no problem. I have a CNC plasma table, welders, etc so building the actual grapple I have no problem with.
I have little experience with hydraulics but I have a good connection for that so I am just going to turn that over to a pro.
What I need some help with is suggestions for what I should do for bushings. Assuming I go with a typical tractor supply cylinder like the one listed below what should I do as far as bushings?
Cylinder
Grizzly Tie Rod Cylinder, 12 Stroke x 3 in. dia. - For Life Out Here
   / Grapple Build, suggestions for bushings #2
Ask your local steel supplier about thick walled dimensional tubing. I used some for bushings for a project about 10 years ago. You can drill it and tap it for grease fittings. It was not cheap- I think it was about $15-20 per foot.
I might be overthinking it. Lets say the bolt I am going to use that attached the top of the grapple to the bottom is 3/4". If I were to get a bronze/brass bushing with an ID of 3/4" and an OD of 1" and then press that into some 1.5" .250 wall DOM (1"ID) then would that work for my purposes?
   / Grapple Build, suggestions for bushings #4
Yes- that is the most professional way to do it- but most heavy equipment uses greasable steel bushings.
If you were wanting to save some time and $, I would just use the 3/4" ID dimensional tubing for the 3/4" hinge pin, then drill/tap it for a grease zerk and use the plasma cutter to make a 1" diameter hole in the frame of the grapple then weld the dimensional tubing in place.
   / Grapple Build, suggestions for bushings #5
I have used forged steel shaft couplings. Get the ones with no key-way. They are drilled and tapped for set screws which may work for zerks. Just cut to length needed. The wall thickness is roughly 1/4" so distortion from welding is minimal. I run an expandable reamer through them after welding. Line up is your biggest problem probably. A heating tip and 20 ton press helps there. I order them on Amazon. IMHO for the intended, use bronze bushings are an overkill and probably wear faster anyway due to the impact loads. I kave never seen them used on implements, only rotating shafts.
Ron
   / Grapple Build, suggestions for bushings #6
If you happen to have round stock on hand, a drilled hole works too. While a lathe is easiest, if you use the pin to locate the bushing before welding it in, how centered it is in the stock doesn't matter as long as the pin is in the right spot when you are done.
There are a couple of thread sizes for zerks, I usually just use 1/4-28 (NF) ones because they are easy and I can find them everywhere, but if you have 1/8 pipe tap that works too.
If all the other zerks on the machine are metric (6-1mm, I think...?) matching those isn't a bad idea. But if they are BSPF I would stick to something easier to get. :p
   / Grapple Build, suggestions for bushings #7
That will work great but be prepared to ream the 3/4" bore out after pressing in/welding because with my experience with bronze/brass bushings they almost always close up after pressing in. It's hard to bore them out to the right size before pressing them in because you don't know how much they will close up.
   / Grapple Build, suggestions for bushings #10
+1 for Misumi. Decent prices and you have lots of options.
I first looked at shaft collars. Shaft couplings are longer and have thicker walls. Most collars are less than 1/2 long. I googled shaft couplings and came up with many sources and settled on Amazon due to free shipping.
Ron
2013 John Deere 824K (A53472)
2013 John Deere...
BUSH HOG 7007 LOT NUMBER 111 (A53084)
BUSH HOG 7007 LOT...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
