Grand L series suspension seat any upgrades
   / Grand L series suspension seat any upgrades #1
USCG1
West Kentucky
L3560
The suspension seat that comes on the L3560 is a joke. Is there anything that can be done to keep it from bottoming out? I have it turned all the way up and it still bottoms out. It would be one thing if I weighed 400lbs but I don't l weigh 225lbs. I'm thinking about trying to had bigger springs if possible. I can even ride this thing across my 13 acre field without my neck hurting from the jarring.
   / Grand L series suspension seat any upgrades #2
I put bigger seat return springs to my L4330 and then added a couple tennis balls to my seat. I weigh +275 lbs = there is no seat adjustment for me. :(
I added 4 springs inside the 4 that was all ready there and it helped a little. Each spring was rated at 25lbs so that give me 100lbs more spring action, but it still sucks.
   / Grand L series suspension seat any upgrades #4
I love mine. I came from the STD L seat and it's no comparison. I haven't bottomed mine since purchasing and I don't think it's on the firmest setting. Of course you a have a few extra lbs on me.
I'm sorry a susension seat that can't handle a person that's 6'3 and 225lbs isn't much of a seat in my book.
   / Grand L series suspension seat any upgrades #6
I'm just messing with yah.
   / Grand L series suspension seat any upgrades #7
I'll have to check where mine is adjusted but it rarely if ever bottoms out, I'm 6' 2" and probably pushing over 200 lbs now (if I don't weigh myself I still call it 190).
   / Grand L series suspension seat any upgrades #8
I'm 6'5", about 260 and mine rides low and bottoms out. I put 1.5" square tube spacers between the sliders and the suspension base, helps to get a better position, but still too low.
Need to stiffen up the springs.
Somewhere, somebody knows the specs on those springs. We just need to figure out their length and rate. Then buy some aftermarket that are stronger. (Easier said than done of course...)
   / Grand L series suspension seat any upgrades #10
Not a lot of info regarding swapping out the springs for heavier ones.
I'll take my seat apart again tonight and take some measurements. If successful, I'll share with all of the other larger than normal kubota drivers.
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Skid steer auger plate (A50322)
Skid steer auger...
