grain drill
   / grain drill #1
dennisleary
Brooks, Ca
kubota 4760
I'm in the market for a no-till or minimal till drill. I have a 50HP Kubota. Any recommendations? I'm thinking about a 6' width. Not sure if I should go with a 3point mounted model or a drawbar-type unit. I'll be using it for seeding oats and vetch, mostly. Thanks.
   / grain drill #2
Kasco has a few drills that will fit your tractor
   / grain drill #3
I'd try the 3-pt version and add a lot of weight or use a hydraulic down force unit. You need a lot of pressure to get one of these no-tills to work properly.
Just Google "3 point hitch hydraulic down force" to see what's available.
Good luck.
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
UNUSED FUTURE FT-BC63 63" HYD BRUSH CUTTER (A51248)
UNUSED FUTURE...
2015 KUBOTA M9960 LOT NUMBER 198 (A53084)
2015 KUBOTA M9960...
2018 Ford Fusion Sedan (A51694)
2018 Ford Fusion...
