GRADER
   / GRADER #1
laurencen
Veteran Member
saskatchewan Canada
Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
Just saw advert on the box (CNN) for a DR grader, it is pulled behing a ATV, looks simple and other than when it gets hard pulling causing the leading edge to lift it seems to work, there are a few good ideas such as the front teeth to rough the ground up, anyone else seen it, bet there will be a few modified versions showing up over winter
   / GRADER #2
http://www.drpower.com/TwoStepCateg...e=2&cm_re=Home Page 1-_-Machine Line-Up-_-PGR
Competitors' different approach
TRACTOR TOWED "DURA- GRADERS"
   / GRADER #3
That second one (dura grader) looks like it would be easy to make.
   / GRADER #4
Agree on the easy to make!
You can fab a lot of grader type things for the price to buy a DR.
I just wish I had a long dirt drive and I'd make one.
ron
   / GRADER
one thing I noticed when building mine we used old grader blades, the front one ended cutting slots every couple inches so it would bite in hard ground, the DR has carbide tipped lathe tools, neat idea, will have to start saving the worn tooling from the CNC
   / GRADER #7
Aquaman said:
I've always wondered if railroad spikes would make good teeth for a grader. Just wondered if anybody had tried it.
I doubt that they would last very long. I believe that they are just soft metal. Might work good while they lasted though.
   / GRADER #8
I have one for sale, if you are interested. You can send a PM. They work very well but too small for my needs.
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
BUNDLE OF 6" I BEAMS UP TO 51" (A54756)
BUNDLE OF 6" I...
UNUSED LANDHONOR LHR-EW20000 ELECTRIC WINCH (A54757)
UNUSED LANDHONOR...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
