Kubota M108 FWA loader, 2014 Kubota M7060,Kubota MX 5100, Ford 1500, Kubota Bx25 , Kubota RTV900, Kubota ZD331 Zero turn mower.Kubota B1200 Grey to be restored.
Very interesting! would love to see more pics, hopefully you will be cutting it out of it's parking spot and resurrecting it!! It looks as though it may be home built but definitely has some engineering built into it.
IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
And worth a few bucks to the right person..!! If you have a long driveway, this is the machine to maintain it. Looks like hydraulic lift too, that'd be sweet..!!
Probably belonged to a Township to grade their gravel roads, and sold after getting a motor grader. The long wheel base makes for a nice smooth grading job.
Looks like it says Gledhill on the frame. Same company that makes snow plows for on highways. gledhill home Standard cutting edges should bolt right up.
Most definitely worth cutting the trees to get it out..!!
