Grader blade for a JD 1530
   / Grader blade for a JD 1530 #1
browncountyoh
John Deere 1530
I just purchased a JD 1530. I think the hp is about 45. It is 6ft. from tire to tire in back. My questions are, should I buy a 7ft. blade so when I angle it, it will still be wider than my back tires. Also is 45hp enough for 7ft. blade. Any advice is greatly appreciated!
Thanks!!!
Brent
   / Grader blade for a JD 1530 #2
Welcome to the forum.
The Deere should handle it just fine. You won't grade more than it can handle, so whatever you do grade, will include the area outside your tires. What could be better than that?
Sounds like you'll have a good rig.
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
1266 (A50490)
1266 (A50490)
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
