% Grade vs Degrees
   / % Grade vs Degrees #1
NewToy
Veteran Member
Ohio
'05 Farmtrac 270DTC
Anyone know what the difference between % of a grade as opposed to how many degrees the grade is? I always see the signs on the hiway saying 5% grade and it sure seems awfully steep.
Thanks,
John
Thanks,
John
   / % Grade vs Degrees #3
I believe % grade is a measure of the rise to the run or how much the roadway rises compared to the length. If a roadway rose 1' for each 1' of length, that would be 100% grade (or the same as 45°). A 5% grade would rise 1' for each 20' of length or about 2-1/2°. When you are looking into a grade, your perspective is distorted. If you looked at the grade from the side, it would look a lot less imposing.
Disclaimer: There is a good possibility that my explanation is completely bogus, it's just my own understanding or lack of same. /forums/images/graemlins/smirk.gif /forums/images/graemlins/laugh.gif
   / % Grade vs Degrees #4
   / % Grade vs Degrees #5
Percent grade is just the rise over run. A 45 degree slope is 100% as the rise and run are the same. Your 5% grade is 5 feet in 100 which calculates to 2.86 degrees. The formula is Angle = ATAN (Rise/Run).
If you think 5% feels steep, try that 100% grade sometime /forums/images/graemlins/smile.gif
   / % Grade vs Degrees #6
   / % Grade vs Degrees #7
Here is how I figure 5% grade. 5/100=.05. Then take .05 and inverse tan which gives you 2.862405 degrees. Hope this helps.
   / % Grade vs Degrees #8
   / % Grade vs Degrees #9
Here's a LINK to a grade calculator.
   / % Grade vs Degrees #10
2022 AIRMAN SDG25  GENERATOR (A45046)
2022 AIRMAN SDG25...
2017 Takeuchi TL12V2 Skid Steer (A44391)
2017 Takeuchi...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A43004)
2017 KENWORTH T680...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
Wacker Neuson WP1550 Vibratory Plate Compactor (A42745)
Wacker Neuson...
