Grade Math help
   / Grade Math help #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Just real quick. One area that I am interested in mowing has a rise of 40ft every 100. It is not the steepest part of the property, but one that I need to clean up soon .. Is this a 25% grade? I looked around TBN and I know someone had posted the math, just can't seem to find it.
Carl
   / Grade Math help #2
Hope this will help you understand Carl.
Not my best blueprint drawing, but it should give you the basics.
All the best. Bill
   / Grade Math help #3
Slope equals rise over run. A rise of 40 feet over a run of 100 feet would be a 40% grade. I don't think I'd want to mow that!
   / Grade Math help #4
That angle is 21.8 degrees
Inverse Tangent of 0.4 (Opposite / Adjacent) = 21.8
   / Grade Math help
Egon said:
Is the run measured horizontally or on the slope?:D
It is Horizontal, not on slope. I am using a high quality Topo the county has. It is pretty accurate.
Really, what I want to do is find out what a 40 or 45 degree slope feels like. And what a 30 degree slope is like... May not need the 1845 after all....
Carl
   / Grade Math help #7
Carl
I go up and down stuff like that with my PT425.
40' up in 100' forward is the same as:
up 4' in 10'
up 2' in 5'
up 1' in 2.5'
up 6" in 15"
I have to transfer the weight of my brush mower to the front tires when I go up the hill by taking it out of float and lifting it about a half an inch. Then I have plenty of traction.
Here's a quick reference for you:
A 100% grade is 1' up for 1' forward = 45 degree slope.
A 50% grade is 6" up for 1' forward = 22.5 degree slope.
A 25% grade is 3" up for 1' forward = 11.25 degree slope.
A 12.5% grade is 1.5" up for 1' forward = 5.625 degree slope.
So you can see that your 6" up in 15" forward slope is less than a 22.5 degree slope. You should have no problems with a PT on that slope.
Hope this helps. :)
   / Grade Math help
I found another spot that needs attention. It is around 27 in slope (110 ft vertical rise for every 400 feet horizontal). Think the 1430 with a brush hog or grapple bucket can handle this slope?
   / Grade Math help #9
That's 15.4 degrees
Almost any model of P T is supposed to be able to handle that one.
   / Grade Math help
Ooops 110 over 300....
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2013 Ford Taurus AWD Sedan (A55853)
2013 Ford Taurus...
2022 Club Car Tempo Golf Cart (A55853)
2022 Club Car...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
