canadianstrom
- Joined
- Mar 27, 2011
- Messages
- 23
- Tractor
- Kioti DS4510 HST, Kubota GR2100
Good Day
I have a GR2110 with about 300 hours with a couple of intermittant issues.
1 sometimes the starter just clicks, either try again, or release and reapply brake or tap starter and it fires right up
2 sometimes after several seconds after getting off running machine ( blades off) at low idle the motor stops
I'm wondering if one of the safetys are causing it ( seat , blade or brake). Or is the machine charging system suspect? I do have 13.5 V on battery when running, 1/4 idle so I think thats ok, battery shows 12.6 V after mowing. I recently cleaned connections at ground, battery and starter. The seat safety switch shows continuity easily, maybe a questionable conection else where?
Thanks for any thoughts or Ideas
