gpm flow question
   / gpm flow question #1
FredSG
Patten, Maine
JD 4052R JD 4310, 825i Gator
Hello,
My tractor has a pump flow of 13.9 gpm. I'm looking at a diverter kit - one is rated at 13 gpm and the other is rated at 15 gpm. Is one a better choice than the other? Thanks, FredSG
   / gpm flow question #3
Are you talking about your 4310?
If so, you DONT have 13.9gpm. Thats total flow of which 5.3gpm is JUST the steering.
You only have 8.6gpm available for loader and implements.
But beyond that, whats the difference in the two diverters other than 13 vs 15 gpm? Price?, Brand?, availability? Quality?
   / gpm flow question
LD1,
I was looking at the Universal Diverter offerings from Summit - someone on You Tube used the Summit diverter with 15 gpm, and then I read that there is a possibility of hydraulics "overheating" from constant movement if the diverter gpm is rated too high? Not sure I understand the heating comment. So I thought I'd post the original question.
When I emailed Summit their email response was to select the 15 gpm diverter. I just thought the 13 gpm diverter would be a closer/lower acceptable match for my 4310.
FredSG
   / gpm flow question #5
Valves typically have a flow rating based on either a performance limit where they may not shift or operate above a given flow or based on a given pressure loss at a given flow.
The concern for heat is based on the pressure loss through the diverter at a given flow.
Since diverter is typically not a metering control valve going larger is not a concern like using a 25 GPM loader valve on a 5 GPM circuit
   / gpm flow question #6
Larger wont hurt. But if this is indeed for the 4310, you only have 8.6gpm, NOT 13.9. So either valve would work. Honestly if all else is equal, go with whats cheaper
   / gpm flow question
Thanks guys, Appreciate your posts and the diverter is for my 4310.
FredSG
New/Unused 20ft Metal Farm Driveway Gate (A48837)
New/Unused 20ft...
Year: 2013 Make: Chevrolet Model: Impala Vehicle Type: Passenger Car Mileage: 167,032 Plate: Body (A48082)
Year: 2013 Make...
2014 Crane Carrier Low Entry New Way 31Yd Side Loader Garbage Truck (A48081)
2014 Crane Carrier...
2022 Forest River Cherokee Grey Wolf 23MK Patriot Edition 29ft. T/A Travel Trailer (A48082)
2022 Forest River...
2021 Chevrolet Silverado 1500 Custom Crew Cab Pickup Truck (A48081)
2021 Chevrolet...
10' X 6' TILT ATV / UTV HAULING S/A TRAILER (A50459)
10' X 6' TILT ATV...
