Loader GPM and operating pressure
   / GPM and operating pressure #1
farmboy238
Holly Springs, NC
Kioti DK45se HST + JD 4066m
I have a DK45se Hst I would like to know what the operating hydraulic pressure is on this machine, also if I am reading my book right it says that the pump capacity is 63.9 gpm. Can that be correct? That seems to be a little much to me. Any help on this will be greatly appreciated.
   / GPM and operating pressure #3
To amplify, the main pressure relief valve is supposed to be set at 2560 psi. Other relief valves (like on the loader) are usually set lower.
The hydraulic pump has two sections. The smaller section supports the power steering and some control functions (like PTO and 4WD clutches). The main hydraulic pump is rated at 9.62 GPM at 2600 RPM. The number you cite is probably liters/min. Flow at lower RPMs is proportionately lower.
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Auger Skid Steer Attachment (A50322)
Auger Skid Steer...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
