Governor Problem on L185DT
   / Governor Problem on L185DT #1
LeeZ
Has anyone experienced governor problems on a L185D (or similar) ?
The throttle control would , intermittently, not let the engine go to full rpm (2850)
and now will only idle. The throttle linkage is good and moves the arm on the
governor shaft and the engine stays at idle. Is it possible that the governor spring
is bad ? It appears that removing the governor assembly is a major job including
removing the front axle assembly.
Any thoughts are welcome
Lee
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A50854)
2021 ALLIANCE...
