Got the backhoe stuck today
   / Got the backhoe stuck today #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Doing some tiling today. Got buried. From the pictures you can see why we are running a tile.
She couldnt walk herself out of this one. Using the hoe and loader to lift, we filled the ruts with some firewood and used the kubota to pull.
IMG_20150321_134828_695.jpgIMG_20150321_134826_314.jpgIMG_20150321_134840_626.jpgIMG_20150321_134852_087.jpg
   / Got the backhoe stuck today #2
That was stuck pretty good. Are you in an old pond bed or just a low area?
Just a low wet area. It is about 50 yards from a leaky pond though. You can see the pond bank in the background among all the brush
   / Got the backhoe stuck today #4
Was there just not enough "bottom" for the hoe to push down on and lift the tractor?
Yes the hoe would lift the tractor, but as buried as the front was, it still wouldnt push through it.
If it was my hoe I would have used the swing and tried to find firmer footing for the rear axle. But dads 4500 has a swing chain. And he has broke it once doing that a time before.
   / Got the backhoe stuck today #6
That's some impressive mud!
   / Got the backhoe stuck today #7
That is a fine job of getting stuck.
Well done, my friend!
So you got it out, you say?
Must have been close to some solid ground, cause that that machine is in there.
   / Got the backhoe stuck today #8
You need different tires. Slicks are not mud approved!:D
   / Got the backhoe stuck today #9
What he said, Be sure to update your resume, employers are looking for people with that kind of thoroughness ;)
   / Got the backhoe stuck today #10
Nicely done!
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
Fire Truck (A51692)
Fire Truck (A51692)
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
